i just ordered some stans no tube sealant for my tyres and also the injector. first time ive done this so advice please. can i put sealent in without taking my wheels off, also is it a matter of just letting tyres down, putting sealent in valve and then reinflate tyre, and give the wheel a spin to move the sealant around the tyre, cheers.
Yes.
Haven't you got to put a rim strip in?
Don't forget to take the valve core out before you put the sealant in with the injector, you will end up with a blocked valve otherwise.
I just use the yellow tape, worked on non-tubeless rims and much cheaper. I used the kit CRC sells for Hope Hoops and they worked perfectly on my Mavic crossride.
Do you have inner tubes in your tyres? The general idea is you don't use inner tubes, put in some tape and a valve to seal up the holes in the rim, inflate the tyre without a tube, put sealant in through the valve havi g removed the core, re inflate, shake it about a bit then go riding!
It is easier to take the wheel out unless you are topping up an already tubeless wheel!
i have crossmax xl wheels and panaracer tyres.
Are the tyres normal ones or UST tubeless?
GB
there are ust wheels and tyres, i saw a couple of videos on youtube where people put sealent in pumped tyres up and they exploded. wheels are on my bike and inflated just need step by step how to put the sealent in with the notubes injector correctly.
I wouldn't bother using the injector. Just shake the bottle really well, leave it upside down for a few minutes then shake again. Then unpop the tyre beads, pour in the sealant and then re-inflate.
Its only worth sticking it in through the valve if you are not confident about removing the tyres.
I've got a small bottle I fill and put into the valve core but to be honest it's just as easy to take them pop a few inches of beading off the rim and pour a couple of cups in
The injector is OK to a point, but dont press the syringe hard, go gently at it. I've had the sealant bung up the valve stem as it acts as though the valve stem is a puncture. Much easier to pour into tyre with a few inches of bead removed from rim.
cheers everyone know what im doing now.
Just ordered some wheels using Flow rims. If I get some 'Stans' valves and sealant do I really also need to get the 'proper' rim strips or can I get away with regular tape?
Also, "a couple of cups" of sealant per tyre - how much is this?
slainte ❓ rob
I'm sure but don't quote me that flows are tubeless ready rims,so you only need a valve the yellow tape and the sealant ,basically the couple of cups is two lid fulls,it will make more sense when you get the sealant,i would buy the biggest amount of sealant you can though as you can use a fair bit if its not going right to start with
colournoise - you just need to seal the rim bed with stans yellow tape, you dont need the rubber rim strip. you need the wider of the 2 sizes of yellow tape for the flow rim.
when you get a bottle of stans sealant it comes with a red cup thing on the top, one of those full should do it. an awkward tyre may leak a bit initially and need 2.
edit - oh yes, and an olympic valve
Thanks.
slainte 🙂 rob
+1 for pouring it in through the valve with the core removed its easy !
Get the 2oz bottle and use one full bottle per wheel injector is rubbish IMO.
right need some help attempted to connect stans injector to mavic ust, no luck. i have removed the valve core but when i try to screw the injector on it is too big and i have hardly any thred to turn it on, please help i dont want to take tyre off.
On a related note (and DT5.1's not Stans) any reason to use the Stans tape instead of just electrical tape?
anyone?
Are you using a stans valve, not sure if this makes a difference?!
no mavic valves as i say the injector is too big and the mavic valve is very short with not much thred on.
Go get the stans specific ones, the injector worked fine on my stans valves, the other option is if you have the small stans bottle remove the core and pour in that way, or remove part of the bead and pour in.....
