Fox 36 FIT damper o...
[Closed] Fox 36 FIT damper oil change help!
I need to change the oil in my 2011 36 floats as the compression/rebound isn't working as it used to, and seen the online guide for dismantling the FIT cartridge, which looks far beyond my comfort zone.
Is there any way of just changing the oil in the damper?
Before anyone suggests sending to mojo/LoCo/TFT, I have QECP enduro in 2 weeks time and even if they could get them done in time, I can't be without bike leading up to the race.
#lastminute ๐Ÿ™
Posted : 04/05/2014 8:34 pm
You are ****ed then.
I'm sure Matt a plush suspension (other local specialist) could turn them around I a couple of hours. You just need to get the fork to them.
Which end if the country are you?
(Fwiw I think the FIT cartridge IS the damper oil)
Posted : 05/05/2014 6:49 am
