Fox 34mm Air Shaft ...
[Closed] Fox 34mm Air Shaft Assemblies - how many different ones are there?
I'm currently trying to buy a second hand air shaft and the seller and I are struggling to work out if his one will fit my forks.
I need;
Fox 34mm Air Shaft Assembly 140mm FLOAT LC NA 2 1.214 Bore. (Evol)
He has;
140mm 27.5 34 Factory’s (kashima) 2017/18 model
Are Evol shafts different to standard ones?  I think the Rhythm ones are different?
Posted : 15/03/2019 11:29 am
Just stick the four letter code of your fork into the Fox website and it'll tell you the part numbers that will fit.
https://www.ridefox.com/fox17/help.php?m=bike
Posted : 15/03/2019 1:39 pm
Problem is he doesn't have the forks anymore and isn't certain which model they are (ie if evol or not).
I'm trying to find out if the air shafts are different between models.
Posted : 15/03/2019 1:47 pm
2017 was different to 2018.
Pretty sure 2018 was a revision year.
Posted : 15/03/2019 3:04 pm
2017 and 2018 had different graphics.
That'll help remember and 2017 won't have evol.
Posted : 15/03/2019 3:08 pm
