Fox 32's not l...
[Closed] Fox 32's not locking out
My 32's dont lockout when you turn the lockoutr dial. They firm up but not lockout, whats the cause?
Thanks
Posted : 29/10/2011 9:05 am
do they have the lockout threshold adjuster on the bottom ?
Posted : 29/10/2011 9:28 am
Will be broken! I had to send mine to mojo and they stripped down and replaced the lock out mechanism in the top of the right leg.
Posted : 29/10/2011 9:32 am
 LoCo
The most likely cause is the base valve at the bottom of the damper cartridge, fairly quick job to fix it with a new assembly at around £20/25 for parts.
You can send just the damper cart in for the repair by me if you like or if they're under a year old return for a warranty inspection to Mojo.
Have had a few of the Gen. 3 OB RL carts. in with jammed base valves.
Posted : 29/10/2011 9:40 am
