FOX 32 s--RETIGHTEN...
[Closed] FOX 32 s--RETIGHTENING LHS NUT PROBLEMS
[#2005223]
Ive just carried out the basic15hrservice on a pair of F32s, removing lower legs , cleaning etc as per Mojo instructions; All has gone fine until Ive tried to get the nut on the LEFT (air chamber ) leg torqued to 5.6nM----it just will not tighten properly, the threaded end just spins in the outer housing. Right leg no problems, tightened just fine. What do I do to get the left leg properly tightened up??? many thanks for help on this !!
Posted : 19/09/2010 4:38 pm
is there pressure in the air side? if not put some in. compress the forks a little and try again.
Posted : 19/09/2010 4:43 pm
Yes about 70psi already
compress the forks a bit, awkward to do but gives the push rod something to bite against and stops it spinning.
Posted : 19/09/2010 4:56 pm
Tried that too but still spins......
Posted : 19/09/2010 5:03 pm
