formula R1s -- shim...
[Closed] formula R1s -- shimano rotor compatibility?
Yes, another gripe about formula rotor prices.
Worse in my case as I've got a pair centrelock hubs -- looking at over 100 quid for rotors on wiggle!
anyone know if shimano work ok in R1s?
will I damage anything other than the pads and rotors, if I damage something?
And yes, I've heard the one about buying a porsche and not being able to afford the tyres. . .
Posted : 16/02/2012 10:27 pm
I'm going to be selling a new pair of formula rotors soon, awaiting delivery of new bike but going to change the formula R1's that it comes with for XT.., If interested get in touch.
Posted : 16/02/2012 10:44 pm
They'll fit fine, I've had had formula, avid and alligator rotors on my K24's...best of British setting them up tho they're a royal PITA ๐Ÿ˜€
Posted : 16/02/2012 10:47 pm
I've no idea about Shimano - I run Hope floating with my R1s (the same rotors I previously used with B4SLs). I'm fairly sure Shimano would work just as well though - rotors are in general fairly interchangeable (I've run Formula rotors with Avid brakes). I also have some spare Formula rotors, though 6 bolt ones.
Posted : 16/02/2012 11:12 pm
 Moda
Are formula rotors slightly thinner than some, you may find that they rub a bit more using some of the other brands. Can you not pick up some centre lock 6 bolt adaptors SH and then fit the 6 bolt formulas ?
Posted : 16/02/2012 11:21 pm
thanks all
I've heard of lots of noise running shimano, Moda, not surprised to hear they may be thinner . . .
yes, I have a 6 bolt adaptor and can get another, but my adaptors add 100 g to the hubs;
i have fancy DT hubs and could have stuck with Hope Pro 2s for that kind of weight!!
But silly, I know.
Posted : 17/02/2012 9:07 am
