Wanted forks with 1...
[Closed] Wanted forks with 1 inch threadless steerer
Looking for a set of these can source some rst ones from the states that is what is on the bike already may be the only option but not a high spec fork i believe. The ones on it are elastomers so give u an idea how old it is but it is a 3rd bike custom built so still great nick just want bit more softness in the front tried all uk and e-bay no joy any ideas.
Colin
Posted : 18/07/2011 12:31 am
I believe Marzocchi used to do one (mx comp) with a 1" steerer. Don't know if they are still readily available.
Failing that Retro bike will be a good starting point.
Posted : 18/07/2011 1:38 am
I think that Pace used to make them back in the day - RC35, right? Ebay is your best bet, elastomer again though - I think...
Posted : 18/07/2011 5:53 am
Tried them all lads nothing in uk
Posted : 19/07/2011 3:20 am
 Sam
I would get a rigid fork - either search around bike shops who'd be likely to have something kicking around, or get something made.
Posted : 19/07/2011 5:26 am
I've got some old Judys
Posted : 19/07/2011 5:30 am
If you can find an older (Italian) pair of Marzocchi forks, Windwave can put a new 1" steerer tube in, I had this done on a pair of Z2's a few years ago, not sure if they can do it with the current far east produced forks. You can also get carbon rigid forks new from ebay.
Posted : 19/07/2011 6:58 am
Jimc, afraid they can't do that anymore. Marzocchi/Windwave no longer do 1" steerers and they have run out of stock of the old ones. Same goes for AMP. A RST 1" steerer will fit any of the older Bombers with a removable one though. Either that or Pace forks up to (IIRC)RC36 Pro Class have replaceable steerers, and 1" are available either from Pace themselves or through ForkEnglish. Best bet is patience and constant scouring of ebay& retrobike...
Posted : 19/07/2011 8:01 am
Tried pace etc no one is or can be bothered anymore age of the consumables and all that i have a removable steerer on the rst ones not sure what these would fit like you say the bombers good fork but an old fork too.Nothing wrong with the rsts just these were first generation forks really not a lot of bounce never was ,but dont want to change to something unless it is better and newer or will come up with the ( oh you can't get spares for them anymore scenario when they play up)Rigid not much fun off road worst case as it is custom build new inch and eighth steering tube and respray but thats a long way off.Bet there is someone out there with a pair they think they will never sell.New bike on cycle to work sceme maybe thanks all
Posted : 20/07/2011 12:59 am
I have a set of MX comp air 2006 model 1 inch steerer 85mm travel, hardly used if you are interested.
Posted : 20/07/2011 6:35 am
That would do i forgot to say will they take a v brake ,how much
Posted : 21/07/2011 10:02 am
