Hi All,
Been away from MTBs for a while and I've just been updating my Enduro. Does anyone have any recommendations for forks? It was bought as a frame with some Z1 Freerides but to be honest I'd like something a bit less hefty.
£450 max (give or take a few quid!).
Also, service the rear shock (Fox RL) or replace it?
Thanks,
Rob.
Coil Pikes
RS Revelations? Service the shock.
I've just taken a set of Magura Laurins off mine, 130mm air, very lgiht, perfect on the bike. I'm selling them for £200 + postage if you're interested?
I'm using a 200x50 pro-pedal Vanilla in mine.
Thanks everyone.
Tell me more about this shock hack. I had thought about it but wasn't too sure how it would work. What is the improvement?
I spoke to Spesh UK and they suggested that putting a longer shock in would be a bad idea - but I suppose any manufacturer would.
Rob.
They probably meant longer travel which I actually did try too (200x57) and it worked fine though too much travel for me. The bb as standard is too low and I found I was constantly hitting cranks/my feet. The longer shock raises the bb just enough to sort that out n
I've got a 2004.
Currently it's in the garage fitted with Pike Airs.
As for the rear shock, you'd get great results sending it TF Tuned to get it PUSHed.
