Currently riding ritchey p 29, and quite happy but still getting things sorted
[img][url= https://farm8.staticflickr.com/7620/16200200993_cbd2b57fee_z.jp g" target="_blank">https://farm8.staticflickr.com/7620/16200200993_cbd2b57fee_z.jp g"/> [/img][/url][url= https://flic.kr/p/qFygme ]IMG_20150315_091658816_HDR[/url] by [url= https://www.flickr.com/people/50879761@N05/ ]vondally[/url], on Flickr[/img]
currently has Manitou 100 forks and I am going to put on some carbon on one forks
the bike is designed for 475 mm a to c length, I assumed that the maitou would be that when I actually measure up
the Manitou are 510 giving a 69 degree head angle
so are there any rigid forks with a 500mm plus a to c length?
or does anyone who owns/ed a ritchey feel like sharing there views on the fork that suits the frame best?
Sagged or extended length?
Anwyay, I use Charge rigid forks - 511mm a-c
Syncros made a carbon fork with a 490 mm a to c, pretty sure it was the tallest available. Other than that it would be a custom job I reckon.
Other than that just posted
[i]the Manitou are 510 giving a 69 degree head angle[/i]
[edit]
I was talkign bollocks.
from ritchey...
It's designed around a 100mm fork with sag.
Manitous measured unsagged...........?? Difference???
[i]Manitous measured unsagged...........?? Difference???[/i]
this was what I was trying to say.
IF you sag the forks 30mm then the a-c is 480mm which is as near 475 as makes no difference?
on reflection...when I lock the forks out and there will be limited sag I feel the ride is better...subjective...more of what I ma used too,
Most 100mm 29er seem to be designed around 500-505mm unsagged forks. So really you are looking at 470mm (500-30mm sag) to 485mm (505-20mm sag)long rigid forks at the two extremes. As already said, there is very little around the 480mm mark, even less available around 490mm and less again longer than that. The Kinesis Maxlight IX is light, cheap (£230 on Merlin) and 490mm long although may butcher the gorgeous looks of the Ritchey.
