I might be in the market for a 160mm fork, the question is which is the best all round 160mm fork that can do a bit of everything with adjustable travel? I like the Marzocchi ETA system or something similar, any suggestions will be much appreciated.
Magura Wotan,
Super easy to service, flight control "on the Fly" travel adjust 160mm - 120mm.
Extremely stiff (dual arch), albert select platform control, shim based damping system means they now ramp up better than first gen models.
20mm through axle (rockshox maxle), post mount brake, aluminium steerer,
Bit heavier than fox or rockshox but will handle more abuse, plus you get the upside that the seals actually work on these forks.
Coil Lyrik
The U Turn takes a little while to go from 115 to 160mm but give you infinite adjustment between the 2 extremes, stiff as and so easy to do the basic lower leg service.
Cheers for the posts, the Wotan is looking good and its cheaper than the Lyriks!
