Now it could have been a loose chain ring bolt but I always retighten/check however this morning mid-commute the front ring folded in two and snapped off the spider ๐ฏ
Too much power?
chainline?
POWA LEGS!
only two? what a wuss ๐
probably fatigue take it they are alloy rings?
Yes alloy ring. The french ring brand. Well I was starting to spin out anyway so was due for a step up in ring size ๐
Chain line is spot on- its a singlespeed specific hub etc.
Actually its failed completely thinking about it as I had to tease the chain around and do quite abit of rebending to get it away from the frame!!
the ring will want to bend even if the chainline is spot as when power si applied chain is compressing the ring radially, it will be weaker laterally so will flex laterally rather than radially
what cranks you using?
(Edit) Sugoni cranks and BMX chain
time for a set of decent track cranks and track chainring?
Rootes- see above. Those are fine aren't they?!! Just need a stronger big (steel) ring now?
Two possibilities - weakened by Bingo wee or
[img] http://fosta.typepad.com/.a/6a00d83452a50369e200e55410ce7a8834-800wi [/img]
My money is on dog piss ๐
Happened to me last night resulting in a 3 mile walk home. 4 ride old Sturmey Archer cranks folded and left a nice gouge in my steel frame just as I pulled out onto a roundabout.
I'd like to think it was my awesome power, but actually the cranks seem to be made of cheese.
Happened to me once - one of the chainring bolts had come out hence it couldnt support the power and bent
<Clarkson>
Powerrrrrrrrr!
</Clarkson>
Happened to me last week. Must be the season for it.
Snapped three bolts though. Grrrrrrrrr.
Wow, thats beautiful. What is it Mick?
white eno with boone ti ring mate
How much all in (approx) and from where???
if you have to ask.... ๐
Mick those cranks are gorgious!!
ive seen a few surly rings do that
Aye, I do Mick.. I do... ๐
Exactly the same thing happened to me - I put it down to crap alloy salsa chainring (30 quid)
bedmaker's looks like the crank spider failed.
