I've got a 160mm centrelock XT disc on my back wheel. If I lock the brake I can rock the wheel backwards and forwards a bit and the slack is between the disc and the central mounting part, the bit rivetted to the disc, as if the rivets are loose. Is this a problem or are they supposed to do that?
(one of my mates has one the same . . .)
Mine do that too- i put it down to me mashing the splines one time.
there is meant to be movement to allow it to expand and contract on the spider and so not warp thats the idea of them rather than just looking pimp ๐
or so i was informed ๐
My hopes did this, spoke to hope about it. They slowly wear at the rivots. Basically its a judgement call as to when you think they need to be replaced, mine had 2.5 years hard use. So not to bothered I had to replace it. To be fare to Hope had they been newer they would have replaced it.
Hmm. Mine's been on since Christmas - hardly used at all really.
this is normal on all floating rotors that is what the floating piece is for.
Just that they're not described as floating rotors. That's why I asked - if they are then that's fine.
ah centre lock i misread im not sure about those at all sorry
