Ive been trying to copy the code from flickr to my blog but it says the url in invalid? any tips on how i can get the url to work?
thanks!
What are you trying to copy code to do? Display a picture?
What sort of blog? Wordpress, blogspot etc
cant remember exactly what it's called or how it works... BUT, there is a little widget thingy that pulls your flickr images into a html site. My developer did something similar [url= http://www.sblendedshakes.com/index.html ]> here <[/url].
It's a random selection of images, but i'm sure it could be otherwise as well.
I want to put a photo from my flickr site to blogspot. Ive tried coppying the whole codes on the "share options on flickr but both are invalid. it says thay a url is needed....
It's a while since I've used blogspot but the code from Flickr needs to go into the post box when it's in html mode, you don't need to click the little image items or anything else. It sounds like you're trying to use the compose mode but with Flickr code. You could find the bit in the code that starts http and ends jpg and use that but you'll then be breaking Flickr's terms and conditions.
Did you know you can blog photos and text into blogspot straight from Flickr without going into blogspot at all?
