Fixing chinese ligh...
[Closed] Fixing chinese light conector
5 Users
Hi,
I have had my cheep as chips chinese light for 3 years now, no fires or such like to report. The connector on the head unit (where it attaches to the battery) has started to play up, i gave it a pull last night and its come apart. Is there a way to reasemble these conectors (what tools would I need)
I know easyest solution is to buy another but I have become quite attached to the litte fella.
Posted : 21/10/2014 10:05 am
Try Maplin. You'll need a soldering iron and some heat shrink tape to make it waterproof again. All available from Maplin. Will cost more than a new ebay light though.
Posted : 21/10/2014 10:09 am
The maplin ones arent great tbh. Your best bet ime is to buy a suitable "extension lead" eg from magicshine uk if they still do them and cut off the connector (you'll be left with a spare for the light side).
Be very very careful cutting the old battery side cable. There's a + and - wire in there just waiting to be shorted out with a bang!
Posted : 21/10/2014 10:15 am
Maplin sell the magic shine extension lead for £6. Cut one end off, you have your new connector
Posted : 21/10/2014 10:20 am
Thanks for advice. Doner cable/connector soldered on, light is working again! to waterproof it will a hairdrier work on heat shrink tape or to I have to buy a heat gun?
Posted : 24/10/2014 7:41 am
Hairdrier might work. A lighter will do it just keep it moving.
Posted : 24/10/2014 7:44 am
You can sometimes do it by carefully rubbing a soldering iron across it.
Posted : 24/10/2014 7:46 am
