As above
Only with waterproof socks
EDIT: No, the shoes won't fall apart I was thinking more about you getting trench foot
They will be fine.
If you get them wet, which is enavitable, leave them upside down on a warm radiator overnight.
Job done.
Good I didn't fancy buying a new pair.
Mine survived last winter just fine. Mind you, the winters tend to be drier than the summers up here and much of what fell from the sky last winter was snow. So, I was more impressed that they survived last summer really !
Mine have been thoroughly soaked through a few times and are still fine. They do take ages to dry though!
Mine fell to bits after 1 winter, but they were the older cardboard ones, I think possibly they've fixed that.
Regardless of whether they fall apart, they will be orrible- the world's grippiest sponges, they soak up water and get heavy and freezing cold.
I think the Sombrio X-Shazams are sold out now but if you can find a pair of those, they're as close as you can get to a proper winter flat pedal shoe- downright fantastic.
Don't leave wet Five Tens in the car and let them dry out over a week and then ride, never bothering to clean them. They rot, as I discovered.
Good enough to buy a replacement pair though. I'll just look after them a bit more now. I'll also buy some Freeriders to complement them so I have something for less bleak days and casual local rides plus a spare pare when the Impacts are drying out. Thankfully SE England riding doesn't involve riding through rivers much. It's just riding in Wales, up north, and in the Alps that I find they get seriously waterlogged. They'll struggle to dry overnight so a pain if you're spending several days riding.
Mine have done nearly two years with lots of use. They're a bit tired but I'll get another set next spring when they've died.
Mine also had a layer of cardboard under the insole, it didn't last long so picked it all out.
Have even had them through the washing machine a couple of times (when Mrs. P is out)
Had mine over three years now, used on my daly commute, and weekend , and night rides. The uppers are still in one piece, they've had a bit of tlc. But they're due for a resole soon. They do hold water better than any camelbak, but I've never had an issue with cold feet. I stuff them with newspaper when they get wet, and leave them to dry overnight , and clean and polish them once a month or so. I'll defiantly be replacing them with either the newer version, or Sam Hills depending on what's around at the time.
See previous thread re five tens .............. essentially get a waterproof winter hiking shoe/boot ring "feet first" and send them up there....... They'll send you back a pair of five ten soled winter boots
