Fitting V-brakes to...
[Closed] Fitting V-brakes to disc only frame?
I know it sounds like a dumb question but go with it...
My SS commuter bike is an old late 90s S-Works running V-brakes. It's a touch on the small side for me and I have a spare SS/Slot dropout inbred frame in the garage that would fit me much better (and negate the need for a tensioner), but it doesn't have brake bosses.
Switching to discs on that bike is out of the question - would require new wheels, new forks, buying some discs brakes etc. However, if I could fit the v-brakes to the inbred somehow...
Does nobody make some sort of clamp on brake bosses?
Posted : 30/10/2009 2:08 pm
I'd doubt it as there are tremendous forces put in the pivot points for canti's/v brakes but would be surprised to see any. I wouldn't trust them though. You might be able get some on braze weld onto steel/alloy frames but not sure.
Posted : 30/10/2009 2:15 pm
you could get away with putting a disk on the back only and keep forks etc but as above - the frame won't have been designed for v'brakes and even with a Magura booster you'd be askign for trouble.
You'd be better offering a swap on the classfieds and seeign if you can find someone with the opposite problem (on v's wants disks)?
Posted : 30/10/2009 2:17 pm
You could get a frame builder like Argos to braze some on for you but tbh it'll probably be cheaper to find another retro-ish frame...
Posted : 30/10/2009 2:18 pm
Not pretty but does the job - http://www.ison-distribution.com/ison/english/product.php?part=BSDNVPS
Posted : 30/10/2009 2:26 pm
mtbfix-thats for converting v-brake studs to cantilever isn't it?
If not I want a pair for my disc rigid forks.
Posted : 30/10/2009 2:38 pm
No, it's a BMX part for fitting Vs to a bike that came with a cheapo caliper or U brake. It might require a bit of a fudge anchoring it depending on the frame you have as it uses 2 jubilee clips and, ideally, a bolt through the seatstay bridge or fork crown.
Posted : 30/10/2009 2:45 pm
Hmmm, ok, thought as much.
Cheap SH disc hub for the rear and a bargain disc brake is prob a better idea then.
Cheers for the info
Posted : 30/10/2009 3:24 pm
 Olly
though for the price of a wheel and a brake, you could get a new frame?
Posted : 30/10/2009 3:43 pm
I've got a 90s Spesh Rockhopper frame and forks in red, with slidey drop outs and v-brake bosses if you are interested? Probably looking for around £75 posted for it if you are interested.
Geoff
Posted : 30/10/2009 4:04 pm
Thanks, though to be honest I don't really fancy spending money on a new frame. The S-Works I have at the moment is mostly OK and I was more seeing if there was a way to make the inbred work with those components. If I'm going to spend any money it'll be in a forwards direction by eventually getting some new wheels and discs.
Got an LX hub off the bay a couple months back for £4 so I'll keep an eye out for something like that and a cheapo rear disc brake.
Posted : 30/10/2009 4:48 pm
