Fitting this later ...
[Closed] Fitting this later today see how easy it is!
sus
Posted : 03/06/2020 10:49 am
Ummmm....
What is it?
Posted : 03/06/2020 10:59 am
Use plenty of lube if it is your first time
Posted : 03/06/2020 11:00 am
New debonair spring, I look forward to seeing how you get on....
Buttplug? If so we don't need any more updates thanks.
Posted : 03/06/2020 11:01 am
Posted : 03/06/2020 1:12 pm
Where did it come from? Are they in general stock now?
Posted : 03/06/2020 2:46 pm
I got it from J tech but I ordered it a while back. They are saying more stock mid next month. They were good though and kept me informed all the way through.
Posted : 03/06/2020 2:55 pm
Should be a little trickier, but not much more so that a lowers and air spring service.
Also interested to know what it's like.
Posted : 03/06/2020 3:30 pm
I've made a shaft clamp out of wood so I'm all ready to tackle it tomorrow when my new forks arrive. I know it won't be too difficult especially now I've got the clamp sorted.
Posted : 03/06/2020 5:25 pm
I’ve made a shaft clamp out of wood
You don't need a shaft clamp.
Hex key in top of piston head/spanner on foot nut.
Sorted.
11 mins in.
Posted : 03/06/2020 5:28 pm
Excellent clickbait thread title. 😉
Posted : 03/06/2020 5:32 pm
I've made the clamp as I haven't got access to a vice and wanted to support the length of it while holding the Allen key and spanner. But thanks for the link.
Posted : 03/06/2020 6:09 pm
How was it to install?
Ridden yet?
Posted : 05/06/2020 8:34 am
Interested in how it goes, i'm fitting one this weekend. Any thoughts on how it feels compared to the original?
Posted : 05/06/2020 9:12 am
Sorry guys I've decided to fit it to new forks which I'm also putting in a shorter air spring which hasn't been delivered yet.
Posted : 05/06/2020 9:24 am
Was watching some videos last night and not everyone finds it works all that well. One clown absolutely blathered the shaft in grease.
Its OK in longer 150+ forks but makes shorter travel pikes harsher.
Was going to try one myself but don't think it will fit my 2017 a1 pikes.
I never found the 2019 debonair air shaft any different for me so ended up altering the shim stack in the damper.
Posted : 05/06/2020 1:14 pm
There is a version for the A1-A2 Pikes.
R2 Bikes have various lengths in stock.
2021 debonair upgrade
Posted : 05/06/2020 1:34 pm
Fitted these today, straight forward enough.
Not ridden as its blowing a hooly and pishing doon just now
Posted : 05/06/2020 3:40 pm
This thread has spurred me into taking my pikes apart again. Regrease air shaft and alter shim stack on the rebound to more suit my ebike weight.
Posted : 05/06/2020 5:51 pm
Finally got my new shorter air shaft so have fitted mine. If anyone is doing it to a newer style airshaft then there is no Allen key bolt in the top to hold the shaft while undoing the footnut. My little tool worked a treat, glad I made it now.
Posted : 06/06/2020 11:53 am
Glad your little tool worked. 😁
Posted : 06/06/2020 12:42 pm
This thread is double entendre overload!
Posted : 07/06/2020 3:22 am
