Fitting the drivesi...
[Closed] Fitting the driveside seal to a DT240S rear hub, anyone?
Just changed the central bearing on one of my DT hubs, all went better than expected but just having a spot of bother getting the seal that sits between the freehub and hub back in, it doesn't feel the most durable so not keen to kill it. Any useful hints before i just apply a larger hammer? (other than "use the proper tool"!)
Ta!
Posted : 11/12/2013 11:54 pm
I have a pot of dt swiss. 240s grease if you want before you go bashing it up.
£20 a pot, £10 to you sir! 🙂
Posted : 12/12/2013 2:46 am
I'm good for grease thanks! (slick honey works really well in these)
Posted : 12/12/2013 10:08 am
PS, use freehub (with no bearings in) as seal driver, sorted.
Posted : 15/12/2013 9:48 pm
Make sure you've got the drive ring in the right way up.Otherwise it won't screw in far enough and the seal won't seat no matter what you hit it with.
Posted : 15/12/2013 9:53 pm
It goes with the recessed face down/in, right?
Posted : 16/12/2013 1:51 am
(delayed) yes
Posted : 16/12/2013 8:54 pm
Thank christ for that, I don't want to take it apart again. Cheers!
Posted : 16/12/2013 9:03 pm
