My brother has just pre-ordered a 216x63mm CCDB inline for his Cube Stereo. I also fancy one for my Meta AM (200x57mm), but clearance for the shock itself is very tight - especially the gubbins at the base of the shaft.
Would there be issues with fitting the 216x63 (@ 0 PSI) shock to see if it will fit in the frame itself? - i.e not worried about the longer stroke allowing the back wheel to contact the seat tube and won't be ridden.
Posted : 07/06/2014 11:19 am
Can't see a problem to test frame clearance just don't use it
Posted : 07/06/2014 12:47 pm
I'm pretty sure commencal say remote shocks don't fit. They sell a different swing arm now that will let you for one.
Give it a shot though.
Posted : 07/06/2014 1:13 pm
Ok cheers. They do sell new chainstays for £350 or so, but that makes it a rather expensive upgrade!
Posted : 07/06/2014 2:47 pm
