Fitting a shimano c...
[Closed] Fitting a shimano crank arm to campag bb
Is it possible to fit a Shimano square taper crank arm to a campag bb?
Posted : 31/08/2012 10:36 pm
I can't remember which way round isn't meant to work, tho I think I have seen both work!
I think this way is OK. Someone may correct me
Posted : 31/08/2012 10:38 pm
It will go. Either way. Tapers don't match but WTF. Dog it up tight and keep an eye on it. After a bit the steel BB shaft will make its own taper in an alloy crank.
Posted : 31/08/2012 10:42 pm
Mattsccm that's what I thought. Thanks guys,!
Posted : 31/08/2012 10:57 pm
Have you found an arm rich?
Just about to go and have a good dig in the garage 🙂
Posted : 01/09/2012 12:32 pm
It goes but it's not great. JIS and the other one.
Posted : 01/09/2012 12:36 pm
£25 on Ebay would sort it - http://www.ebay.co.uk/itm/Campagnolo-Centaur-chainset-/120972981037
Posted : 01/09/2012 12:38 pm
Campag is Iso shimano jis i have been trained not to mix the two as your likely to shagg the crank arms.
Posted : 01/09/2012 12:48 pm
