fitting a headset w...
[Closed] fitting a headset without a headset press??
ive got a new headset to fit to my bike but havent got the use of a press.
whats the best way of doing it without knackering the thing!!
cheers
steve
Posted : 29/05/2009 10:10 am
Large lump of wood. Smack. Done.
Posted : 29/05/2009 10:12 am
 sv
M10 or M12 bolt & nut plus some BIG washers and hey presto one headset press. I picked washers that fitted inside the cups so there was less slippage. Went in quite easily.
Posted : 29/05/2009 10:13 am
bench vice
Posted : 29/05/2009 10:14 am
Ive always used a copper/hide mallet, commonly known as a "nammer".
bit of wood and hammer takes about 5 mins
Posted : 29/05/2009 10:17 am
Heat the frame with hot water and freeze the cups. Makes it all go in easier
If you use the hammer method I prefer to support ther frame on my leg so you are working aginst the inertia of the frame rather than hitting it into the floor.
I prefer the home made press out of threaded bar and washers. Just make sure it goes in straight
Posted : 29/05/2009 10:19 am
cheers for that brant , its actually going into an inbred !!
Posted : 29/05/2009 10:25 am
bit of M8/M10 studding and some appropriate nuts'n'washers
easy life
Posted : 29/05/2009 10:30 am
Rubber mallet, very easy.
Posted : 29/05/2009 10:33 am
Not much point in freezing the cups. The temperature change is relatively little, but I suppose it all helps.
I use Kitt's rubber hammer, personally. Unless I can't find that, then I use the block of wood.
Posted : 29/05/2009 12:38 pm
I used some wood and a g-clamp.
Posted : 29/05/2009 12:41 pm
Job done!
cheers
steve
Posted : 29/05/2009 12:48 pm
which method did you use?
Posted : 29/05/2009 1:06 pm
Hammer and block of wood!!
Bish Bash Bosh
Posted : 29/05/2009 1:11 pm
find some washers that fit snuggly into the cups. slowly tighten making sure the cup go in evenly/straight. i've used a series of washers as i found if only using one between the cup and bolt the washer tended to mis-shape.
cost about 1.50 and a bit more precise than a hammer.
Posted : 29/05/2009 1:18 pm
 juan
I used a vice and some wood went in all smooth
Posted : 29/05/2009 1:20 pm
