I'm looking to replace the AFR rear shock on my Enduro SL Pro (M5 alu) with an 09 Fox RP23. Has anyone on here tried the same, will it simply bolt straight on or do I need to get a new mounting kit / bushings etc?
Posted : 23/07/2009 2:11 pm
If your existing bushings are in good condition it should fit straight on but if they arnt then you should be replacing them anyway. I believe (but do check) that they are 22x8 these are great [url] http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=231&Name=Fox+Needle+Roller+Bearing [/url] they are pretty simple to fit if you have a vice and a socket set.
Posted : 23/07/2009 3:22 pm
hi, did you replace the shock, how was it riding after??
Thanks.
Posted : 26/02/2010 3:40 pm
