Fitting a bigger ch...
Fitting a bigger chainring ...
I won't bore you with the why but ...
Since boost became a "standard" and tyre sizes have increased chainring sizes - or more specifically space for chainrings has decreased.
It appears direct mount rings further the issue as spiders seem a thing of the past.
I appreciate that with wide range cassettes you get the spread down low but if you live somewhere devoid of hills spinning out is more likely where I end up - I have a 38T chainring on my Mk1 Solaris!
So ... can anyone shed any advice on how it can be achieved/bodged? I have a frame that states 32T max (:-( ) that I would like to bump up a fair bit.
A non boost chainset with a ring in the outer position?
A boost touring(?) crankset?
Superboost?
Spending time developing a 7T cassette sprocket?
All help/suggestions most welcome.
M
Posted : 09/09/2024 1:35 pm
Classified rear hub 😉
Posted : 09/09/2024 1:50 pm
9 tooth cassette?
edit, saw your 7t comment
how about a 9t cassette and the max permissible ring? because i cant imagine finding or fitting a 38t would be much fun and function particularly well if bodged to work
Posted : 09/09/2024 1:54 pm
 Yak
Yeah, if sram, then a non-boost chainring will give a little more room, or any similar variation to get to a non-boost position. What crank do you have?
Posted : 09/09/2024 2:18 pm
@tom - I don’t follow
@alan - unless I’m missing something (probable) I don’t need the wide range that the SRAM esc cassettes come with
@Yak - I’ve a few that I could try but currently fitted is a SRAM GX? With a direct mount ring.
Posted : 09/09/2024 3:20 pm
13 made cassettes with a 9t smallest
Some of the new "wide" boost chainsets with 55mm chainline might give you move clearance for a bigger ring,
Posted : 09/09/2024 3:55 pm
Old fashioned octalink or square taper bottom brackets are available in a variety of lengths and would allow you to fit a larger chainring at the expense of increasing the chainline.
OP what sort of bike/frame do you have that has a 32T limit, and where/what are you riding that needs a bigger gear than 32:11, with 29x2.2" tyres at cadence of 90rpm thats 36km/h
Posted : 10/09/2024 9:37 am
 Yak
Sorry, got that wrong. You need a boost chainring to move it out and give more room. Non-boost is going the wrong way and closer to the chainstays. So a 3mm offset chainring to fit a direct mount (3 bolt) sram crank would be the boost position. But if you want more clearance, then superstar make a 0mm offset direct mount chainring, so would gain 3mm over the boost position.
Posted : 10/09/2024 10:05 am
 bens
Double chainset with some sort of clamp on front mech?
Or,
Fit some really heavy wheels and stupidly sticky tyres? Maxgrip shorty front and back should do it.
Posted : 10/09/2024 10:33 am
What Tom meant by Classified rear hub...
https://www.classified-cycling.cc/products/powershift-set
Posted : 10/09/2024 12:56 pm
Classified hub will give lower gears surely?
Posted : 10/09/2024 1:43 pm
HammerSchmidt?  IIRC you can get one that is an overdrive
https://www.bike198.com/review-truvativ-hammerschmidt-am-crankset/
Posted : 10/09/2024 1:47 pm
Just run a 2 x setup?
Posted : 10/09/2024 1:50 pm
