First of many Nikon...
[Closed] First of many Nikon D90 questions - UV filter
[#1181268]
Ive heard a few people mention on here about using a UV filter to pretty much just protect your lense from mud and grit.
I'm currentely working my way through varoius tutorial books and the manual (heavy going).
Do UV filters affect the image taken, I'm sure they will, maybe to cut down reflections etc but just want to get something in the short term to protect the lense.
Anyone explain briuefly a recommend one.
Posted : 04/01/2010 10:03 am
Wrong forum sorry
when I said reflections I really meant haze
Posted : 04/01/2010 10:24 am
You'll get lots of people saying not to use UV filters because they degrade image quality. Which is true of cheap ones for sure. I'm not convinced you'll notice the difference with expensive ones (I don't anyway). So... if you're going to get one, get a good one (have a look at B+W MRC UV or protective filters).
Posted : 04/01/2010 10:30 am
I think I've got a fairly pricey Hoya UV filter on both of my lenses.
I haven't taken any comparison shots, but they are supposed to reduce haze (& I think increase contrast).
You do get people recommending that you don't fit them as they degrade image quality, but I haven't noticed any degradation with the images I have taken and I can't afford replacing a lens, because I've scratched the front element, so it's a no-brainer.
The only lenses I probably wouldn't get them for would be a macro lens that normally have quite a recessed front element.
Posted : 04/01/2010 10:43 am
 jim
In general digital cameras aren't significantly sensitive to UV so you won't see any reduction in haze.
I'd agree that you'll probably not see any difference in general, but it is possible that you'll get more flare when shooting towards the sun due to the filter.
I don't use then myself, but always use lens hoods to avoid bashing the front element into things. I think this provides ample protection unless you're shooting in really filthy conditions with mud literally spraying on the lens, but then you might well not put your SLR in such situations anyway.
Posted : 04/01/2010 10:55 am
I used a cheapish UV filter (Hoya green) on my Canon 40D/ 17-85 combo, and I tried several with/without comparisons. I could not tell the difference even zoomed in to 100% on the computer.
I think unless you get a really bad filter then you will only see a difference on top end lenses that give a really good resolution/image quality.
The filter save me on many occasions when out biking when mud got on the front of the lens, and when I forgot to put the lens capback on before putting the camera into its bag. With the filter on I just wiped it clean with my glove rather than worrying about the lens element.
A lens hood is a really good idea too, keeps rain off the front element.
Posted : 04/01/2010 11:47 am
 CHB
I have a top of the range Hoya filter on my 18-200VR lens.Cost about £40 on Ebay. I see no reason not to use one. I guess its a bit like a seatbelt, ie only of benefit in an accident!
Posted : 04/01/2010 11:58 am
As Jim mentioned, it's flare that's the problem. Even when you don't get flare you get lowered contrast or ghosting. For undemanding lighting though I think you're dead right, you'd never tell.
Posted : 04/01/2010 12:05 pm
Cheers for all the info - I've goone for a Hoya Pro-1 multi-coated job for £28 off Amazon. Will see how it goes - just ike the idea of not scratching the lense when I have mud/dirt on my hands:)
Posted : 04/01/2010 12:25 pm
