Fenwicks Fs1 cleane...
[Closed] Fenwicks Fs1 cleaner opinions?
Hi all, opinions please.
I tried a small bottle of fenwicks fs1 that dilutes into 1 litre over the weekend, bought from Amazon in attempt to reduce my cleaning costs, or be able to use more cleaner without worrying.
The fenwicks was no better than p*ss. I hosed off the majority then sprayed it all over the bike, literally didn't do a thing. Then tried again with the same results.
Is it really that bad? Or have I been sold a duff sample or something? I want something comparable with muc off or better, but cheaper that's safe for carbon.
Thanks alot.
Posted : 26/11/2018 9:34 am
Tried out some kingud cleaner at the weekend. Sprayed on dirty bike, left for 5 minutes then rinsed. It worked like a charm!
Its biodegradable and a small family business in wales. What’s not to like?
Posted : 26/11/2018 10:20 am
Tried Juice lubes Dirt Juice for the first time yesterday sprayed it on the bike left for a few minutes then hosed it off & towel dried sorted.....worked like a treat...
Posted : 26/11/2018 11:11 am
Been using FS1 for years, always found it decent stuff. And it doesn't tarnish aluminium like Muc-off.
Piss is actually quite good if you leave for a couple of minutes before rinsing.
Posted : 26/11/2018 11:56 am
Always been an Fenwicks user, chuck some in a bucket and then continue to fill with warm soapy water, then use a selection of brushes to dip into the water and scrub off the bike. Always comes out looking spotless. Tried mucoff before and found it be poor in comparison.
Posted : 26/11/2018 2:28 pm
Another long time FS1 user without issues.
OP - might just have been the way I read it, but did you use any brushes at all?? or just
sprayed it all over the bike, literally didn’t do a thing. Then tried again with the same results.
I've not used anything that doesn't need some agitation to effect the cleaning
Posted : 26/11/2018 2:42 pm
Overpriced dung, all of it. Stardrops, hot water, bucket, brush and a cloth. A quid from my local savers.
Posted : 26/11/2018 2:55 pm
Another FS1 fan here. Never had any problems with it but as mentioned above, it does need a bit of agitation, much like the others of this type.
FS1 neat is also a superb chain degreaser. drip it on, leave for a minute then quickly go over the chain with a toothbrush and hose off. Works perfectly for me 🙂
If you are using it as a chain cleaner make sure you wash it all off then relube ASAP after though.
Posted : 26/11/2018 3:02 pm
Tried Fenwicks and it worked ok diluted a wee bit stronger than recommended.
Then I tried this and it works a lot better (for me) Also a lot cheaper.
https://www.ebay.co.uk/itm/15L-Professional-Motorcycle-Motocross-Bike-Bicycle-Chain-Cleaner-Degreaser/290967791120?_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20170221122447%26meid%3D54abf63706764a10a4ef5285f5210c8b%26pid%3D100752%26rk%3D4%26rkt%3D5%26sd%3D111506460732%26itm%3D290967791120&_trksid=p2047675.c100752.m1982
You obviously don't have to buy 15 litres but it works out cheaper. I dilute it 50:1 for general cleaning and 10:1 for the transmission. I was wary of using it on the brakes at first but no problems after two years of using this. I use it on the bikes and the vehicle fleet. Gets rid of black streaks on the motorhome a treat.
D.
Posted : 26/11/2018 3:35 pm
Cheers for the replies all.
To be honest, I didn't agitate on the frame. I prefer not to as it just scratches it. I don't mind leaving residue or water marks, as long as the majority is off. That's probably why I have to go over it twice, and end up using so much muc off.
Hense me looking for a cheaper alternative. I'm wary of ebay stuff tbh. I'll look into your suggestions tho
Posted : 26/11/2018 6:04 pm
I always keep FS1 around for moments when I need heavy duty bike friendly cleaners. I generally keep some at the 1+9 dilution you’ve probably used in a squirt bottle for drivetrain cleaning.  I honestly hardly ever use it though.  Cheap Halfords car shampoo (not a waxy one) made up in a bucket with warm water and a sponge then a quick hose off usually does me.  Not really a fan of heavy duty cleaners for every time use. Still only takes a few minutes and still looks good...
Posted : 26/11/2018 7:24 pm
I prefer the fenwicks to mucoff still on my first concentrate bottle I use an old mucoff bottle diluted about 8/1 .
i tend to hose down the worst of the mud off then spray it all over ,
then after a few mins (usually hosing down my bag shorts jacket legs etc)
i use an asda soft brush (a lot cheaper than mucoff) to clean it down
i then use the “mucoff bike protect” spray to wipe down with micro fibre cloth, that is the difference .. once dried no streaks or mud
Posted : 26/11/2018 10:11 pm
