Fat front - which h...
[Closed] Fat front - which hub and rim
[#4876965]
Ok, will this hub work? To be used with a salsa enabler fork. Any other hub suggestions welcome.
[url= http://www.tartybikes.co.uk/135mm_fixed_hubs/trialtech_race_sealed_rear_hub/c21p11423.html ]Hub[/url]
With this rim...
[url= http://www.tartybikes.co.uk/26_inch_rear_rims/onza_pro_diamond_rear_26_inch/c25p11185.html ]Rim[/url]
The rim is the same width as the ones used by sandman but I just noticed that the erd is 549 rather than 542 on the trialtech sport lite. Does this actually matter as to be honest I don't understand how you can have a different erd to fit the same size tyre? Is it just a taller sidewall on the rim?
Posted : 16/02/2013 6:53 pm
Hub - No brakes?
I use DMR Revolver single speed hubs in my Enabler.
The rim is wide enough, so it should be ok.
Posted : 16/02/2013 8:01 pm
😳 Good spot on the hub!
Will have a look for a dmr hub. Ta
Posted : 16/02/2013 8:17 pm
