Fat bikers - lowest...
[Closed] Fat bikers - lowest disable pressure on 40-50mm rims?
I think I can just about squeeze a FBN into my Shand, using a mid width rim.
But there's no point unless I can run it softer than a 2.75" Dirt Wizard or 3" Knard (I'm guessing 12psi on trails?)
So how low do you go?
Posted : 11/03/2016 6:51 pm
12-15psi for me usually, though I can imagine running it a wee bit lower for certain conditions.* Remember that the "3.5" FBN is no wider than my 3.0" NN so whatever the KNard runs at would be a good starting point.
(* I run my 4" fat tyres at unfashionably high pressures too - 10-12psi mostly)
Posted : 11/03/2016 7:01 pm
Shame there's so little choice in 26+
Ta
Posted : 11/03/2016 7:15 pm
Disable = usable!
Posted : 11/03/2016 8:29 pm
I think I was on 8-12 psi depending on where I was riding. Generally about 1 or 2 psi more than I used with real 4" tyres.
Less than 8 psi felt gelatinous on my relatively narrow rims.
Posted : 11/03/2016 10:24 pm
