I have an extralite ultrahub front wheel and an curious if the hub can be adapted to 15mm axle... the extralite website alludes to the fact it can be done but it references the hyperhub. The hyperhub looks identical to mine other than name but I'm unsure. Anyone happen to have this obscure knowledge?
I think your best bet would be to ask on weight weenies personally! Think they'd be more likely to know about extralite stuff (happy to be proved wrong though)
As an aside how have you found the extralite hubs? I'm always concerned with bearing life etc with proper weenie parts like those.
Mmm, they're definitely not the same axles, but if the shell's the same then you could theoretically transplant the axle (and bearings if necessary) and end up with a Hyper Front.
Asked Extralite?
