Just an idle thought here. About to send off my old Floats to be refurbished and i thought about whether the travel can be adjusted by removing an internal spacer - is this correct?
Forks are 2004 Float RLC's
I have some 07 RL's were 120 and reduced to 100m by adding the spacer myself.
I am not sure about weather the 04' will go down ?
[url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/04_32_en.pdf ]Float Manual Linky pdf[/url]
i think 04s are 100mm max, you can reduce to 80mm but you can't go longer, a call to mojo or tf may help
No I think they are 100max as I have them on my Wifes HT - They def wont go higher and yes again I think they may go to 80mm by removing a spacer but not sure - again give Mojo/TFT a quick ring ๐
I was just wondering really - i too suspect the 04's were 100mm max travel.
I'll speak to Mojo when i send 'em off next week.
