exceding the max te...
[Closed] exceding the max teeth guide on a rear mech????
 ton
if a rear mechs max teeth guide is 27 teeth cassette, will it work ok with a 28 tooth casette??
Posted : 31/01/2010 2:40 pm
It'll be fine.
Posted : 31/01/2010 2:42 pm
 ton
daffy, how much bigger can you go?
if i decided to try a 32
Posted : 31/01/2010 2:44 pm
You might struggle with interference between the upper jockey wheel and the larger cassette sprockets if you go too high.
you'll know straight away when you try to shift across without the chain on.
Posted : 31/01/2010 2:50 pm
 ton
cheers mate............. 8)
28 is fine .
Posted : 31/01/2010 2:57 pm
