everything you've h...
[Closed] everything you've heard about inbreds is true!
here's the proof
Posted : 05/04/2009 6:39 pm
God you're so juvenile! Make sure you never change! ๐Ÿ˜€
How are you finding the bike? I'm just on the cusp of ordering that same frame - is the rear wheel easy to set up / keep in place? Rear disc performance good? What kind of weight does it come out with the rigid forks?
cheers
|gtth|
Posted : 05/04/2009 6:52 pm
riding buddies bike i'm afraid, but i can tell you he's a lot faster on it than his geared bike and lifting it over styles/gates is not a chore! it's way light
Posted : 05/04/2009 7:09 pm
 aw
Do you find the rigid fork ok compared to a front suspension fork?
I notice that the SS bikes are more inclined to have a rigid fork, why is that?
And the replacement rigid fork in this case - does it take into account the angle of the front end if or compared to a sus fork (in other words is it raised up to the same height as a 4" fork as you would expect the front end to be lower)
Posted : 05/04/2009 7:59 pm
SS bikes are generally owned be weirdo's, hence the rigid fork ๐Ÿ˜‰
Posted : 05/04/2009 8:08 pm
for info-it's a 29er fork, but doesn't seem to upset the handling (not that i've ridden it)
Posted : 05/04/2009 8:12 pm
My SS is very similar to that, with On-One carbon forks, and carbon bars. It gets a bit chattery over rough downhill tracks, especially on chalk. I guess mine's around 20/21lb ish? Keep meaning to get it on some digital scales. Lovely bike to ride, took mine for a blast across the Marlborough Downs and the Ridgeway this afternoon.
Posted : 05/04/2009 9:37 pm
 aw
I guess the real advantage is the weight saving of the carbon rigid fork. 20lbs is light for a MTB
Posted : 05/04/2009 9:54 pm
Is that a 456 with 29er rigids?
Posted : 05/04/2009 10:15 pm
no it's a standard SS inbred
Posted : 06/04/2009 7:07 am
 ski
That's one hell of a ding that right hand Bumb Hole Lane post has taken ๐Ÿ˜‰
Posted : 06/04/2009 7:13 am
trails are extreme 'round these parts ๐Ÿ˜‰
Posted : 06/04/2009 8:52 am
 ski
Not far from my neck of the woods RD either ๐Ÿ˜‰
You might have heard of North Piddle which we cycled past at the weekend.
Posted : 06/04/2009 9:57 am
i've had a few 'piddle in the hole's before now
Posted : 06/04/2009 10:01 am
 Keva
I swapped the rigid fork on my inbred for an 85-115mm reba, I reckon it was better as a rigid, never quite felt as good with the suspension.
Posted : 06/04/2009 10:13 am
