Evenin' all.
Can anyone recommend a place to have an aluminium frame and carbon fork re-sprayed? Not entirely sure whether painting or powder-coating, so any experience of either would be useful too. If anyone has had a frame done in red, it would be good to see a picture of the finished article.
I’m in mid-Wales so likely to have to ship it, so location isn’t too much of a problem.
Ta.
Green is fastest.....FACT!
Actually, Ming, I agree with you! Lime green all the way, if it was for me. Unfortunately it's for a red-obsessed friend!
rule out the forks if going for powder coat. You normally need a conductive substrate that you can earth to get the powder stick but even if you can get it to stick you then need to bake the part which I wouldnt do without knowing the cure temp of the part.
Bristol way you have Argos and also ABC Enamelling who both get good reviews.
+ 1 Argos Racing Cycles
Removed a stuck seat post and resprayed my '94 Cinder Cone. Superb job
Thanks for the suggestions so far. Some great work done on show by Argos and Fat Creations.
I'm on a bit of a tight timescale having only just come up with the idea of a re-spray for a friend's birthday. Anyone had good results from anywhere in a fairly short space of time?
