European brakes... ...
[Closed] European brakes... Wrong way?
[#3565019]
I am thinking of ordering a set of SLX brakes from Germany, but obviously the levers will be on the wrong side. Is it just a case of unscrewing the hoses, swapping the levers and re-bleeding or is there any other hidden secrets I am not aware of?
Posted : 14/01/2012 5:32 pm
Its as simple as you suggest! Just unscrew and rebleed.
Posted : 14/01/2012 5:33 pm
Cheers 🙂
Are the new SLX brakes easy to bleed?
Posted : 14/01/2012 5:35 pm
 awh
You might not need to re-bleed even. I've swapped 3 sets of XT without needing to.
Posted : 14/01/2012 5:40 pm
Got some SLX brakes recently. I took the hose out, cut to length, popped in the new insert and olive (included) and swapped them over to the right way round without needing a bleed. Cushty.
Posted : 14/01/2012 5:42 pm
Ah does the fluid just stay in the various bits then? Sounds good! I'm more tempted to spend money now!
Is there a special way of not losing the fluid?
Posted : 14/01/2012 5:44 pm
 awh
I've not needed a special technique. I just cut the hose to length, swap left and right hoses, attach the new the olive and tighten everything up. I think there's a Shimano guide for doing this on their website.
Posted : 14/01/2012 5:52 pm
I run euro anyway just put them on as they came 🙂
Posted : 14/01/2012 5:58 pm
The capillary action is enough to keep the fluid in place and negate any bubbles - mostly. Seems to work on most hydraulic brakes.
Posted : 14/01/2012 7:00 pm
