ESI Grips - Rubbing...
[Closed] ESI Grips - Rubbing Alcohol to install question....
Got my first pair of ESI grips last week and see that you need to install them using 'rubbing alcohol' which after a look on the net this is the equivalent surgical spirit.
The other half has popped to the supermarket tonight so I asked her to have a look for some surgical spirit and she has come back with a bottle made by Care +.
However on closer inspection the ingredients are Caster Oil and Methyl Salicylate - to which I am guessing is not what I should be using?
What have other people used??
Posted : 04/07/2013 8:20 pm
Anything that evaporates quickly; aftershave will do.
Posted : 04/07/2013 8:21 pm
I used alcohol gel (hand cleanser stuff)
Works really well!
Posted : 04/07/2013 8:23 pm
i used water, no problems at all, left overnight in the shed they will not budge.
Posted : 04/07/2013 8:24 pm
Windolene works wonders.
Use it to get them on, leave it overnight & they will be good to go in the a.m.
Disc brake cleaner works a treat.
Posted : 04/07/2013 8:27 pm
Mr muscle window cleaner here to left for 18/24 hours all good.
Posted : 04/07/2013 8:28 pm
I did it with water on 2 pairs. No problem.
Water works to get them off too.
Posted : 04/07/2013 8:29 pm
Mr Muscle window cleaner here too. Fitted about 4 sets with that with no issues.
as above,Window cleaner,disk brake cleaner or Isopropynol Alcohol
Posted : 04/07/2013 8:30 pm
I normally use IPA (Isopropyl Alcohol) but I have just used the old favourite, hairspray tonight in the absence of anything else!
Posted : 04/07/2013 8:31 pm
window cleaner
Posted : 04/07/2013 8:33 pm
 cp
window cleaner for me, worked a treat
Window cleaner. It actually says to use this on the packet (the ones I've had anyway). I found IPA evaporated too quickly.
Posted : 04/07/2013 8:40 pm
Rubbing alcohol is Isopropyl alcohol IIRC. Fast evapourating relatively low hazard, won't dissolve the grips.
Aftershave, deodorant, water, disc brake cleaner I have used in the past with success.
Posted : 04/07/2013 8:41 pm
I used alchohol swabs from first aid.
Posted : 04/07/2013 8:44 pm
put 4 straight zip ties through the grip at 90 degree points around the center of the grip then slide twist the grip on with the cable ties acting as a smooth bearing surface to aid pushing them on, then use some pliers grab the end nob of the cable tie and while holding the grip in place pull them out one by one.
Works for all grips and needs no evaporating lube etc
Posted : 04/07/2013 8:48 pm
+1 for antibacterial hand wash. Worked a treat and evaporates quickly. Took a couple of minutes to install both grips.
Posted : 04/07/2013 8:54 pm
I did wonder about the hand wash stuff, will give that ago.
Many thanks STW oracles!!!
Posted : 04/07/2013 9:11 pm
Feistys tip above will work - the reason I go for diskbrake cleaner is it also dissolves any oily residue on the bars.
Posted : 04/07/2013 11:17 pm
+1 Disk brake cleaner.
Posted : 04/07/2013 11:38 pm
I used a spray of deodorant. Worked fine and dried but then I realised the instructions said to move the fat part to where your palms are... Didn't even notice there was a fat and thin part to the grip.
Aside from that, really comfy grips. Only wish I'd got black ones though as I bought orange as they were super cheap. Doesn't really match anything on the bike but yeah, comfy as and much nicer than my old Oury lock ons.
Posted : 05/07/2013 5:22 am
Spray mount adhesive works ace on all grips including ESI (which I use)
Posted : 05/07/2013 6:00 am
I put on a set last night, wet the inside of the grip and the outside of the bar then put a squirt of washing up liquid on there too, wrapped the grip in a rag (so I could grip it) then pushed it on while my dad held the other side of the bike as it was pretty tough, probably took about a minute per side.
Posted : 05/07/2013 8:39 am
water alone does the trick. leave overnight and sorted.
helps to put your riding gloves on to be able to grip it better.
i found the super chunky ones a little more tricky to do though.
Posted : 05/07/2013 9:55 am
I found if you wiggle them back and forth to get them on it's a lot easier than just pushing it! Just don't lose track of where the thick part is.
Posted : 05/07/2013 10:15 am
