Epic kit advice
[Closed] Epic kit advice
I keep learning the hard way and then figuring out what I should have carried with me on >6 hr rides. Doh!
In addition to food + drink, puncture repair kit / spare tubes and a mini tool (alien 2) I take spare pads, cable ties, long nosed pliers, - what essential or slightly quirky kit to you take that might save the long walk back? Cheers
Posted : 19/08/2012 9:16 pm
Quick links
Posted : 19/08/2012 9:18 pm
tire boot
Posted : 19/08/2012 9:24 pm
Yeah toothpaste tube for a tyre boot. Maybe a chain splitter if there's not one on the tool
Posted : 19/08/2012 9:25 pm
Spare pads shouldn't normally be neccesary, unless you ride somewhere gritty... That's something better taken care of before the ride. Good preperation is more effective than carrying tons of kit.
Quicklinks, definately. Money- might be obvious but after accidentally going out for a ride with no cash, I stuck a £20 note in with my little bag of tools and spares. Mech hanger as appropriate. And I have a single spare M5 and M6 bolt, in case of falling out.
Posted : 19/08/2012 9:27 pm
Some sort of warm garment in case of mechanical disaster in bad weather. Something that doesn't take up loads of space.
Posted : 19/08/2012 9:32 pm
spare legs/lungs
Posted : 19/08/2012 9:39 pm
Quick links, do actually have them
Alien tool has handy chain spitter and wee wire to hold the ends together
Never thought of a tyre boot. @ scratch colgate or aquafresh?
Cheers northwind, sage advice re money. Will add a mech hanger to the list and a couple of bolts for good measure
@ g_l, good thinking.
@ bruneep, is that an offer?
Keep them coming!
Posted : 19/08/2012 10:03 pm
Some gaffer tape wrapped around your pump. And a couple of zip ties. Good for bodging stuff back together.
Posted : 19/08/2012 10:11 pm
Some oil - I use one of those little fishes you get with sushi - good for one chain application and weighs nothing.
Posted : 20/08/2012 6:11 am
Spare cleat bolt. I've never needed one but have handed them out twice.
Mind you mine always seem to end up welded into the shoe...
Posted : 20/08/2012 7:18 am
Always have a set of pads in, just easier really.
Spare links and tool for chain
Fizzy Snakes
Posted : 20/08/2012 7:23 am
 br
First aid kit (used again on Sunday)
Space blanket - never used one in 30 years of walking/climbing, but...
Latex gloves
Gel
One gear cable
2 co2 cannisters - run tubeless
Tyre boot (3"x3" piece cut from an old tyre)
Posted : 20/08/2012 7:45 am
 IA
Mech hanger!
Gel or some fast energy stashed somewhere, for when it all goes tits and you need that pick me up to get home.
Posted : 20/08/2012 8:23 am
@b r
Latex gloves & gel?
You're not from round here, are you, boy? 😉
Posted : 20/08/2012 10:41 am
Map & Compass
Posted : 20/08/2012 10:47 am
Brake pad springs & spare bolt / split pin for when you drop one in the grass.
Small knife.
Nurofen.
Posted : 20/08/2012 10:56 am
My tool kit has:
Pump
Lights (headtorch & rear light)
2 Inner tubes
Emergency Poncho
Alien multi-tool
Leatherman
Spare brake pads
Tyre boots
Gear cable
Random set of bolts inc SPD, chainring bolts, etc
DUCT tape wrapped round pencil
Puncture repair stuff
Cable ties
Mini shock pump
Then my Camelbak always has a First Aid Kit, Space blanket, whistle and compass in it + iPhone booster battery
Posted : 20/08/2012 11:01 am
I'd really suggest a couple of good mates! Most valuable thing you can pack. Failing that a bike mechanic and an A&E Doctor
Posted : 20/08/2012 11:08 am
+1 for gloves. Better than getting covered in dirt/chain gunk when doing repairs.
Posted : 20/08/2012 11:19 am
Love the gaffer/ duct tape idea + oil in sushi fish 😀
Spare bolts..yup should have been on the list
Not sure about the gloves, as a wee bit of dirt/ muck is usually the sign of a good ride 😕
+1 for medical kit - and I've not considered a survival blanket previously but will now - AMK heatsheets bivvies seem to get good reviews - will perhaps add emergency distress/ howler whistle to the list too
Map/ compass a great idea and easy to forget when you tend to rely on smartphone gps
Out of interest - can you/ does anyone convert their schrader shock pump valve to presta to negate the need for 2 pumps?
Posted : 20/08/2012 9:44 pm
i have used hockey tape as a tyre boot on a road tyre, which obviously runs at much higher pressures, its good because it doesnt stretch.
not sure if it would work so well on a much larger mtb tyre though.
as well as having various tools, knowing how to use them would be good.
boy scout innit, be prepared.
Posted : 20/08/2012 9:59 pm
Simple, take schrader tubes
Posted : 20/08/2012 10:06 pm
Inflating tubes with a shock pump takes a while. Do you really consider a shock pump to be an essential? Most of the time, if your shock/fork loses air, it's knackered.
Posted : 20/08/2012 10:08 pm
Latex gloves, gel and Fizzy Snakes?
Cant help but thinking there's a correlation...
Shock Pumps now. FFS - how far do some of you boys actually ever get from civilization - 4 miles max would be my guess...
Posted : 20/08/2012 10:12 pm
 poly
I recon my form of epic riding goes about as far from civilisation / roads as anyone is likely to be in the UK. I have never taken a shock pump with me. On a multi day trip, where we were remote from cars / lbs each night I think ONE of the group carried a shock pump. None of us used it. I don't recall anyone ever wanting to tweak shocks mid ride on an "epic".
I've only ever changed break pads 'in the field' once and that was laziness for not replacing part worn pads before we left.
The only mechanical failure that ever left me "stuck" (fortunately reasonably local) was a sheared crank bolt. Everything else has been bodgeable with the kit people describe above, although a broken rear mech (not the hanger) effectively ended the ride for me with a single speed back to the car.
Posted : 20/08/2012 11:27 pm
Duck tape wrapped around pump.
Credit/Debit card - Had to replace a seatpost mid ride once! (Luck would have it that I was only a 20-25 minute ride from a shop).
Salmon pin boning pliers - small and light.
Posted : 21/08/2012 6:24 am
This shock pump weighs less than 100g.
http://bemufail.info/topeak-pocket-shock-masterblaster-pump.aspx
Posted : 21/08/2012 6:35 am
The only failure I've not been able to fix was a sheared freewheel, which happened in the middle of a three week trip in the USA. Luckily a local rider leant me a spare wheel which I posted back to him at the end of the holiday (as we were in another state by then).
Posted : 21/08/2012 6:41 am
>Salmon pin boning pliers<
I never go anywhere without these either. Then there's the fly rod, reel and portable fish smoker...
Posted : 21/08/2012 6:58 am
As far as I want. It's light and even more use for very long routes where you might want to firm everything up for half the ride.
It is possible to travel a long way with a sensible pack. By the time you add 3l of water and some food everything else is small change. Also after it pisses it down it doesn't really matter.
You do know thats soy sauce in those, not oil right? 😉
Posted : 21/08/2012 7:02 am
Only one call for a rear mech?
Gloves, i know what you mean about a bit of dirt, but 3 words
puncture, dog, sh*t.
Spare pads, clips ,springs bolts to fit them, never mind wearing them out, i've seen the braking material come off the the backing, pads just leave the bike, as if by magic.
tyre boot plastic milk bottle carton, cut a rectangle out if fact cut two, you can enjoy the smiles from random strangers when you give them away then.
I also cut one up once to make spacers to re mount a mates front brake after the bolts came lose. worked well.
Posted : 21/08/2012 7:59 am
My Camelbak normally weighs about 8kg. I pretty much always have an SLR + lens selection, 3l water, tools, food, rain jacket etc. It's been all over the world with me on various mountain biking trips.
Posted : 21/08/2012 8:01 am
Thanks for all the great tips guys. If I substitute the fishing tackle for the shock pump and take one sushi fish full of soy I may indulge in some sashimi to refuel on the epic. theblackmount - fancy sharing any fishing tips?
Posted : 21/08/2012 9:46 pm
After your warm sashimi you may very well need some bog roll. It's light, small ( you don't need the whole roll).
It won't save your life but may save your arse.
Posted : 21/08/2012 10:24 pm
Sure.
I've always found a Handline and mackeral feathers a very versatile piece of kit.
Posted : 22/08/2012 8:07 am
@ Hugor
Clearly you're not familiar with the 1 x Rizzla paper technique!
Posted : 22/08/2012 8:09 am
Back to theblackmount's favourite topic: anyone tried one of these topeak shock n roll pumps and care to give any feedback. V little available online at the mo: http://www.bikerumor.com/2011/09/28/interbike-want-topeak-shock-and-roll-pump/ Cheers
Posted : 23/08/2012 9:23 pm
Rab Photon Hoody
Gore active shell trousers
Wooly hat
Spare warm gloves
Leg and arm warmers
Gilet
Map and compass
Charged phone
First aid kit and knowledge of how to use it
Rab waterproof jacket
survival bag
whistle
Spare food
Tools
Pump
Tyre boot
Gorilla tape
Zip ties
Spare mech hanger
Spare gear cable
Tiny container of chain lube
Dry bags to hold them all in
It sounds like a lot but they pack easily into an Alpkit Gourdon 20 with plenty of space to spare and to be honest, it's not that heavy.
Add in a couple of spare shorts and tops and toiletries and that's what I take for Alpine hut to hut trips. All of the gear has been used and I've often been very grateful that I brought it when the weather has gone to shit or a mate has had a mishap or mechanical.
The one thing I will add is a small shock pump. Riding down the Col de la Possette last September after the air had slowly pissed out of my forks had me kicking myself for not bringing one. You only need for it to spoil a ride once for you to decide to take one.
Sanny
Posted : 23/08/2012 10:23 pm
Ohhh and dont forget the bike! 😀
Posted : 23/08/2012 10:40 pm
Sanny you have clearly pissed all over everyone's epicness and kit list with that post.
Posted : 24/08/2012 5:36 am
Sanny you have clearly pissed all over everyone's epicness and kit list with that post.[i]
Eh? What on earth are you blabbering on about? Have you been on the buckie? The OP asked what stuff folk take on big rides so I replied. I'm not looking to wee on anyone, thank you very much! 😀
Posted : 24/08/2012 8:17 am
Err, "Hut to hut" Alps storming is not really your common or garden epic - hence my rather tongue in cheek comment.
You can put your handbag away now, kit lists are always fair game for a bit of banter 😉
Posted : 24/08/2012 10:04 am
plastic pill case with some chamois cream inhowever much you put on,it never lasts more than 5hs.
broadsheet newspaper page-you can stuff it down the front of your jersey on downhills if you get cold.,like you do on the road.folds up smaller than the smallest gilet.you can use it as bog paper if you need,you can read it if you sit down somewhere.
little camping hammock,when it's hot.
ziplock bags (small)with sugar/salt mix.
some biscuits.
rear light.
multitool,pump.bit of cash.bit of a bar of soap,good for washing your hands/wounds.
Posted : 24/08/2012 5:10 pm
