Engineering help ne...
[Closed] Engineering help needed. Rivnut replacement
My Ibis Tranny has a loose rivnut and I can't undo the bolt as the rivnut just spins. Ibis were great and sent a replacement but I can't fit it as I don't have the rivnut tool. Is there someone located around Wiltshire, Hampshire or Dorset that could drill the old one out and fit the new rivnut?
Thanks all!
Posted : 26/08/2014 11:40 am
A blob of superglue might secure the existing nut enough to be able to remove the bolt. At the very least that makes it a lot easier to drill out the rivnut.
Posted : 26/08/2014 12:00 pm
Am I the only one not so keen on the idea of popping a rivnut into a carbon tube? is that really what they do?
Posted : 26/08/2014 12:15 pm
Easier than welding.
Posted : 26/08/2014 12:17 pm
if you drill it out, will you not end up with a few rattly bits of left overs in the tube forever?
Posted : 26/08/2014 12:18 pm
IME you can usually get those bits out via the rivnut hole or other holes in the frame.
You don't need a rivnut gun to do a rivnut up.
http://home.btconnect.com/astro-site/pulling_rivnuts.htm
Posted : 26/08/2014 12:19 pm
Chances are that if you can get the bolt out, you'll be able to simply tighten up the existing rivnut it's quite east to do with a bolt and a couple of nuts.
Posted : 26/08/2014 12:21 pm
You should do a video for that. You're right.
Posted : 26/08/2014 12:26 pm
Thanks for the replies everyone. I had tried superglue but I had no luck. @keith I have no idea about debris will rattle through the frame. Thanks for the help so far, I appreciate replies.
Posted : 26/08/2014 1:42 pm
What sort of bolt is stuck in the rivnut? You may be able to get some mole grips on the bolt head to hold whilst you drill through the threaded length. Start with a small drill and work your way up in drill size till you take the bolt head off.
Install as nemesis suggested.
Posted : 26/08/2014 10:37 pm
Would happily do it on mine but not some else's pride and joy, just in case! But as for removal - dremels were made for this kind of thing. Small bit and some water, and lots of patience with gentle cuts.
As for putting it in, as above bolt with nuts and washers. Quite slow but maximum feel for a thin/fragile bike frame compared to the proper tool which can be cumbersome. As you're only doing it the once you don't need the tool IMHO.
Posted : 26/08/2014 11:10 pm
if you have a friendly car repairer or garage nearby they should have the tools to take these in and out, although you risk letting a grease monkey on your pride and joy ๐Ÿ˜†
Posted : 27/08/2014 8:34 am
