Enduro sl bearings
[Closed] Enduro sl bearings
Hi I'm in the process of changing the suspension bearings on my 2008 enduro sl. I'm attempting to change the BB Pivot bearings 6802 rs. I have got the nut off (19mm socket) but cant seem to get the pivot axel out ?
I've tried knocking it through from non drive chain side but it wont budge.
Is there something i'm missing ?
Any help would be much appreciated
Posted : 07/02/2011 7:18 pm
non-drive side bearing rusted/siezed onto shaft?
releasing spray, let it soak a while?
Posted : 07/02/2011 7:30 pm
looks similar to the set up on my pitch. the same thing happened with mine, i used 3 in 1 penetrating oil left over night then applied more. I still had to support the frame on some wooden blocks and smash the thing out with a hammer. i had to hit it really hard and it made a horrible sound.
for the bearings i had to use a massive vice to press them out.
Posted : 07/02/2011 7:39 pm
Chain device in the way?
It should just bash out, keep going at it, just use something softer between hammer and end of the axle as it's alloy.
Posted : 07/02/2011 7:41 pm
I know when I changed the bearings on my 08 enduro, I had to give it more hammer action than felt right. Sorry i can`t give you more technical info, just protect everything if using a hammer, as mentioned above. I also used some wooden blocks to lay the frame on to give it something to push against.
Posted : 07/02/2011 10:11 pm
Thanks for the replies, checked with a few Specialized service dealers nearby
and I'm getting all 12 bearing fitted for £45 😀
Posted : 08/02/2011 7:00 pm
