Endura Stealth Jack...
[Closed] Endura Stealth Jacket ?
 gamo
How do you wash these and how often? also do they become less waterproof
with washing? Ta.
Posted : 09/02/2009 12:10 pm
 rj
I do mine at 30deg using a mild detergent with no softener or fragrance, then once in a while I use Grangers 2 in 1 stuff to keep the waterproofness um, waterproof.
Posted : 09/02/2009 12:16 pm
Use either Nikwax Techwash, or if you can get it , Lux flakes, as these are a soap, not a detergent - they're suitable for most, if not all technical waterproof stuff. The key is to avoid detergents altogether if you can. I use the Nikwax re-proofer, but I'm sure the Grangers stuff will be fine as well.
Posted : 09/02/2009 12:22 pm
Think you're meant to tumble dry them for a bit too?
Posted : 09/02/2009 12:25 pm
Most of the time I wash mine at 30 deg with no detergent - you're only really getting mud off rather than lots of sweat. I understood that the issue with detergents is not that they make it less waterproof but that particles block up the pores making it less breatheable
Posted : 09/02/2009 1:43 pm
 jfeb
Washing my "waterproof" shorts with normal detergent [b]definitely[/b] made them un-waterproof. Fixed with Nikwax though.
Posted : 09/02/2009 2:56 pm
