Ebike not touched s...
Ebike not touched since November
[#13167298]
Just wheeled the ebike out to give it a check over as it's not been used since November (Gravel bike has been out instead). Spesh Turbo levo SL. It was given a good clean before it's winter hibernation, however.....
Chain looks a bit rusty, and the brake discs have a bit of corrosion.
So these will be replaced, anything else on the bike I'll need to check over?
Battery was left at 50% and is currently charging.
Posted : 24/02/2024 3:47 pm
I wouldn't even replace the chain or rotors, lube the chain and using the brakes will clear any surface corrosion. Apart from that pump the tyres up and you're probably good to go
Posted : 24/02/2024 4:00 pm
thols2, murdooverthehill, davros and 27 people reacted
Oil chain and ride. The discs will probably clean up after one descent.
Posted : 24/02/2024 4:25 pm
zerocool, the-muffin-man, the-muffin-man and 1 people reacted
What dc1988 said.
Posted : 24/02/2024 4:35 pm
What they all said!
Posted : 24/02/2024 4:41 pm
Why?
Posted : 24/02/2024 4:43 pm
Has anyone suggested just lubing the chain and going riding yet?
Posted : 24/02/2024 5:06 pm
dc1988, geeh, zerocool and 5 people reacted
I certainly wouldn’t replace the discs.
But i might replace the chain, lubing it will make an excellent grinding paste.
Posted : 24/02/2024 5:09 pm
zerocool and zerocool reacted
It's easy enough to get rid of surface rust on the chain with (not too aggressive) a steel brush or scourer. Just take it off first of course.
Posted : 24/02/2024 5:19 pm
🤣🤣🤣 cheers for the advice. Ok, I'll keep the rotors but for piece of mind I'll do the chain.
Posted : 24/02/2024 5:21 pm
So these will be replaced, anything else on the bike I’ll need to check over?
The tyre pressures. And the flux capacitor obviously. Hope it's still under warranty...
I'd just check the chain with a chain wear gauge thing and, as long as it's in tolerance, give it a quick brush and some lube.
Posted : 24/02/2024 5:23 pm
My chain is rusty 9/10 times I get it out of the shed (weekly basis). Discs probably are too
Oil it, ride it
Posted : 24/02/2024 6:29 pm
The question is, is the chain rusty.
Often what’s rusting is the small particles of rust sitting on the chain. If the chain is flexible then that suggests no rust where it matters.
Posted : 24/02/2024 6:33 pm
dc1988 and dc1988 reacted
Changing chain seems a total waste of money. Just slap some oil on it and use the bike.
Not sure why people are so precious about this kind of thing.
What are we thinking could happen if you leave a bit of rust on a chain?
Posted : 24/02/2024 7:04 pm
convert, goby, goby and 1 people reacted
Lube chain, charge battery and go ride it...the brakes will sharpen up after the first dozen pulls.
Posted : 24/02/2024 7:10 pm
On a Levo SL the button battery (#EDIT: cr1620 and stores the bluetooth settings etc) will fail at some point and generate an error mid ride that will ruin your day / weekend as it shuts the tcu down. 99p preventative fix. As I've learned the hard way. You will need plastic tweezers, or insulating tape on normal tweezers to get the thing out.
Otherwise: just use it! The brake rust will rub off.
Posted : 24/02/2024 7:49 pm
"What are we thinking could happen if you leave a bit of rust on a chain?"
He might get catapulted off the bike and straight into a tree surgeons working wood chipper.... you gotta think through all the possible eventualities...
Posted : 24/02/2024 9:30 pm
 mc
Cause rapid wear, as obviously rust is far more abrasive than riding through some mud...🙄
Posted : 24/02/2024 11:05 pm
Cause rapid wear, as obviously rust is far more abrasive than riding through some mud…
Is it? Depends what's in your mud. Plenty of it is harder than basic iron oxide, the softest particles are about the same.
Posted : 25/02/2024 10:26 am
OP, if the chain's dry (it probably is if it's rusty) give it a good brush with an old nail brush or tooth brush, top and bottom, run it through a rag, squirt with an airline if you have a compressor, get as much as you can, because while it's dry, it's loose, as soon as you get lube on, it'll stick.
Posted : 25/02/2024 10:34 am
OK, so most rust on refined steel will be on the harder end of muds you might ride in.
Posted : 25/02/2024 11:04 am
 mert
I just run the chain through an oily rage if it's got surface rust.
Can usually tell by the sound it makes if there's any rust inside (or if it needs a *serious* oiling/waxing).
Posted : 25/02/2024 8:53 pm
Used my ebike for the first time since October earlier this month and just pumped up the tyres and charged the battery, bikes are pretty resilient, just look at any bike rack outside tescos or the likes 😂
Posted : 25/02/2024 9:01 pm
I just run the chain through an oily rage if it’s got surface rust.
You need to relax. Getting upset won't help your chain.
Posted : 25/02/2024 9:03 pm
thols2, ayjaydoubleyou, prawny and 5 people reacted
The whole bike is scrap I'm afraid.
Seriously, just lube the chain and ride it. It'll be absolutely fine.
Posted : 25/02/2024 9:04 pm
Everyone is missing the obvious point, which is that you should oil the chain and go for a ride.
Posted : 25/02/2024 11:22 pm
So just to confirm, I can just oil the chain? And then go for a ride.
Posted : 26/02/2024 8:56 am
Yes, or you can oil the chain then go back inside and spend several hours on internet forums arguing about how often chains should be replaced. Or not oil the chain and stay inside on internet forums arguing about whether it's necessary to oil chains if you don't ride the bike.
Posted : 26/02/2024 9:00 am
No, you should be waxing your chain in the first place. Time to start a new thread asking about that 😉
Posted : 26/02/2024 9:40 am
jacobff and jacobff reacted
If you change the chain, unless it's brand new or very low miles, you'll almost certainly get some skipping with the cassette.
Just slap some oil on, rub with a rag and go play on your bike. As has been suggested above.
Posted : 26/02/2024 1:00 pm
I've always considered rust as a porous coating to help retain lubrication?
Posted : 26/02/2024 1:24 pm
euain and euain reacted
Long may it stay like that 😉
Posted : 26/02/2024 1:32 pm
Maybe also check caliper pistons are moving equally too.
Posted : 28/02/2024 4:05 pm
Given it has been a few days since you posted this - assuming you have now ridden it - how was it?
Posted : 28/02/2024 4:08 pm
Where do you keep your bikes so that the chain and discs can corrode in this somewhat short period of time?
Posted : 28/02/2024 4:45 pm
