Easton haven droppe...
[Closed] Easton haven dropper remote & fox transfer post
Are these compatible?
Posted : 03/07/2017 8:33 pm
Yes, in as much as both ends will clamp the cable, so you could just cut the nipple off.
Posted : 03/07/2017 8:41 pm
So does the lever end clamp the cable?
The post needs the nipple end on the transfer.
Posted : 03/07/2017 8:46 pm
The Easton dropper post clamps the cable and nipple is used in the leaver.
Posted : 03/07/2017 10:03 pm
Not compatable. I paired my Fox Transfer with a Wolftooth LA and it's worlds better than the original Fox lever.
Posted : 03/07/2017 10:11 pm
Anyone know of a good lever that clamps the cable?
Posted : 03/07/2017 10:12 pm
^^^ see post above yours ๐Ÿ˜€
Posted : 03/07/2017 10:14 pm
Ah, ta.
Posted : 03/07/2017 10:35 pm
Cheers Ian, just trying to save some coin. The wolftooth looks good but it is pricey.
Also can't decide if I need the easy pull one
Posted : 03/07/2017 10:56 pm
Agree it is pretty pricey. I went for the light action one as have arthritis in thumb. I was genuinely surprised just how light the lever action is though.
Posted : 03/07/2017 11:08 pm
The bontrager one clamps at the lever. Works well too.
Posted : 04/07/2017 11:16 pm
Yeah, sorry, for some reason I read that the other way around. Thought you wanted and Easton post with a fox lever.
I've got the fox lever, wouldn't mind looking at the wolftooth light action for my Thomson. Partly because it would mount to my Hope brake levers.
Posted : 05/07/2017 6:45 am
I personally wouldn't pair the wolftooth LA lever with Hope ispec brakes. I use the standard one and have it fully inboard, I think the longer length of the LA lever would get in the way.
Posted : 05/07/2017 10:24 pm
Cheers for that. Just how far inboard to you have it as I run my Hope brakes a long way in compared to other folks.
Posted : 06/07/2017 6:39 pm
I have about an inch gap between the grip and shifter. The wolf tooth lever has about 1/4" of adjustment and I have it all the way in.
Posted : 09/07/2017 9:54 pm
