DTSwiss - Torque Ca...
DTSwiss - Torque Cap to Standard
Hi
I bought some wheels a while back built on DT Swiss 240 EXP hubs, and specified torque caps as they were going onto a set of Rock Shox forks. I'm about to swap to Fox, so need to get a set of the non torque caps to make them fit. Trying to decipher the DT Swiss site, and it looks like I need part number HWGXXX00S2757S (from 'kit components' on: https://www.dtswiss.com/en/support/product-support?matnr=H240BDIXR32SA6481S)
Can anyone confirm that this is the right part, and know of anywhere that keeps them in stock? I can find places that have the TC conversion, but not the standard end caps ๐Ÿ™
Failing that, anyone have some DT 240 EXP hubs with standard ends and fancies a swap to torque caps?
Jon
Posted : 01/05/2025 1:57 pm
That does appear to be the ones - thanks!
Posted : 01/05/2025 3:32 pm
Those are for the oversized hub. You only need that version if your front hub accepts 20mm axles. I suspect that this will not be the case though as the 15mm max version is much more common.ย
Posted : 01/05/2025 4:00 pm
Drop the DT Service Centre an Email with a photo of your hub's serial number, they'll be able to get some for you.ย
ย +441908326032
DTSwissService@madison.co.uk
ย
Posted : 01/05/2025 5:02 pm
I'll swap you if you like?ย  I've been dealing with the very minor faff of lining up non torque cap wheels with RS torque cap forkholes for a while.ย  ย
Posted : 01/05/2025 5:54 pm
Nedrapier - PMd.. ๐Ÿ™‚
Posted : 01/05/2025 6:52 pm
