Best place to buy one please?
If you are building DT rims, you can do that using a spare spoke to feed the nipples in through the rim and tighten using a standard spoke wrench, if that makes things easier and cheaper...
Pretty much any bike shop can get you one. They arent all that expensive and in stock with Madison.
Thought I'd better use the proper tools for the job. Will ask in the bike shop.
Make sure you have some spare nipples, I rounded a couple of the squorx ones off and would have been screwed without a couple of spares.
Got millions of them by the look of it.
If you bought rims, you get 2 spare per rim.
An 'E5' external Torx socket fits the Squorx nipples. I don't know it the official tool is different, but the socket didn't hold the nipple securely enough to feed it through the rim without risking it dropping out (especially with the washers on, too). Still needed to use the 'cut-off cotton bud' / 'spare spoke' trick to get them fitted, then the socket on a screwdriver to wind all the nipples down to the end of the spoke threads. I still ended up doing the tensioning and truing with a conventional spoke key.
Ahh, the size is useful to know. I'll look for that, thanks.
I made a tool using a standard disc rotor bolt (same size as squorx nipple head) which worked like a charm.
Didn't fancy spending £15 on a tool I'd use a couple of times at the most.
Genius, I'm gonna do that 🙂
That's very ingenious stevied - well done sir!
Had I read this before last week I'd have saved myself €15 on the part
Here is my effort. Was a pain trying to drill a hole against the grain of the wood, kept going off to the side. Not tried it yet.
[URL= http://i196.photobucket.com/albums/aa301/krzysiu4001/IMG_0921.jp g" target="_blank">
http://i196.photobucket.com/albums/aa301/krzysiu4001/IMG_0921.jp g"/> [/IMG][/URL]
I got one from Germany. I also bought black squorx nipples but they had to be sent from another German company.
