dt swiss hub geeks ...
[Closed] dt swiss hub geeks to the forum please
Just bought some dt swiss XR10 wheels from a spark 10 and want to know if the front can be converted to 15mm bolt through (currently QR)can't seem to find out any info on this wheels set
Posted : 19/12/2013 3:46 pm
 juan
From what I can see there is not such wheels.If you are refereing to the XR 1.0 Carbon, they are already 15mm 370/350 hubs with the 15mm to QR adaptator.
Are the hub shell gentlty moving?
Posted : 19/12/2013 4:18 pm
No definitely Xr10 I think they were made only for the spark 10 2011,proberbly re badged 240's but not sure
Posted : 19/12/2013 4:47 pm
 juan
Well you have to be sure. Are the hub shell on the side moving gently.
I can't really see OEM wheels being 240. Specially for scott.
My guess will be that they are 350 therefore not convertible from 5 to 15mm. But I need to know for sure
Posted : 19/12/2013 5:06 pm
 juan
http://www.dtswiss.com/Accessories/Conversion-kits
Posted : 19/12/2013 5:25 pm
End caps should just pull off - check the axle diameter. There is a version of the 240 which is QR specific, but most can be converted.
You may need an axle, you may just need end caps.
Posted : 19/12/2013 5:27 pm
There's been OEM 240s in the past- Giant and Trek at least, maybe others. Pics would be helpful tbh
Posted : 19/12/2013 5:39 pm
Loads of companies use DT 240 internals in their hubs - Bontrager, Roval, CycleOps, so it's entirely plausible.
Posted : 19/12/2013 5:40 pm
 juan
For OEM it's more 350 than 240. Front hub is very likely to be a 350/370.
And Njee it's omre there is a 240 version that is fifteen and the others QR/TB.
Posted : 19/12/2013 6:02 pm
Nope, as I said, Bontrager, Roval and CycleOps all use 240 internals. Fronts are a bit different - they're usually in different shells, so the 350/240 point is moot.
Aye, but you can convert both to 15 - as it's OEM it's not a given which it is.
Posted : 19/12/2013 6:17 pm
 juan
[b]Nope, as I said, Bontrager, Roval and CycleOps all use 240 internals[/b]
Doesn't mean it's a 240, as the 350 use the same internals as the 350.
And you CAN'T convert a non fifteen QR front hub to a 15mm
Posted : 06/01/2014 4:39 pm
