Just put on a tyre and rimpact. Everytime I pump the tyre up all the air releases through the drain hole?
what to do???
is the tape damaged
Posted : 20/09/2021 8:11 pm
It's just finding the path of least resistance so yes likely a tape or valve issue
Posted : 20/09/2021 8:39 pm
Rim tape or valve.
Posted : 20/09/2021 8:41 pm
Probably caught the tape as you were putting the rimpact in, easily done.
Posted : 21/09/2021 12:13 am
Tighten up the rim pact Valve stem with a pair of pliers
Posted : 21/09/2021 3:27 am
I had this on some carbon wheels.
The front was fine with gorilla tape. The rear took 6 attempts to stop the air coming out the drain hole.
Using Tesla tape and wider gromits on the valve sorted it for me.
Posted : 21/09/2021 8:02 am
