Hi,
I've a DT 350 hub which I've just purchased an XD freehub for. Parts arrived however end cap seems too short, its flush with the cassette. Guessing I've ended up with a 135mm end cap.
Anyone know of an end cap to suit boost 148 or have one spare?
Thanks
You can file the top hat bit on the old end cap down if you’re desperate or cheap (I’m the latter).
Bit cheeky, but I'm looking for a qr endcap for my 350 rear hub. If you don't need it for something else, I'd gladly take it, or them off you.
I'm also the latter.
Actually, I've just had a look in my spares box. I have the end caps to make 12 mm x 142 mm if you would be interested in a swap?
I guess this won't work for you unless the driver is a bit longer than the shimano 10 speed freehub that I'm measuring them on.
My XD end cap is 135x12mm so won't be any good for you.
Taken the file to the old 142 Shimano end cap and works fine on the XD. Top tip thanks.
