Anyone know where I can get a standard Shimano freehub driver for a dt Swiss 350 hub, ideally in the UK to avoid any import fees, had a look about and can't seem to find anything
Thanks
Sjs?
Assuming 12mm axle and you need the endcap as well (if you have XD you will) https://www.sjscycles.co.uk/hub-spares/dt-swiss-ratchet-freehub-conversion-kit-for-shimano-mtb-12-x-142mm-or-boost/
Looks like they also have the qr version available.
Excellent the one I thought would fit was £150 I was just pricing up 12 speed instead 🤣, I'm going from boost 12mm microspline to boost 12mm Shimano old style.
I will get that ordered thank you for your help
You'll probably get a fair chunk of it back selling the microspline version.
I might have one in the cellar - I’ll have a look
Weirdly sounds similar to what i did, 12sp microspline and switched to 12sp HG and stuck on the SRAM 12 speed hyperglide cassette.
I do have one from when I switched to XD. You would need to use your existing ratchet parts, but it has 12mm axle endcap. Endcap sticks out 7mm beyond the end of the free hub body.
You can have it if it’s of use to you.
