Dt Swiss 350 front ...
[Closed] Dt Swiss 350 front hub 110x15 to 100x12?
4 Users
Anyone bought the 100x12 end caps and tried them on their 110x15 front 350?
I thought it wouldn’t work at first as it would need to be a non boost hub but have seen conflicting reports
Posted : 28/03/2021 8:43 pm
Won't work. You'll have a 110x12 hub. You need the non boost hub shell.
Posted : 28/03/2021 8:53 pm
Just cut a 10mm ring out of the centre of the hub and weld it back together.
Posted : 28/03/2021 9:10 pm
You shouldn’t even need to weld it. The tension of the spokes, clamping force of the thru axle and main axle for alignement should keep it all together
Posted : 28/03/2021 9:18 pm
