DT Swiss 240 front ...
[Closed] DT Swiss 240 front adaptors - how to remove?
The adaptors on my front 240 oversize hub screw on to the axle and they're both a RH thread.
Once you get one off, how on earth do you get the second one off? Unscrewing it just results in the axle spinning.
I've tried to grip it from inside with the maxle but can't get it tight enough.
Any help appreciated, ta.
Posted : 05/08/2019 10:08 pm
 tdog
I guess you’re meant to place in vice
Eeeeeck ! Some may say
I cannot even remember how I changed mine as ages ago bitd
Posted : 05/08/2019 10:13 pm
Dont you just pull it off ? (s****)
or maybe....Remove one by unscrewing. Tap out the axle and use soft grip vice to hold the axle while unscrewing the other by holding the axle with a rag while unscrewing the end cap
Posted : 05/08/2019 10:14 pm
Doh! Remove the axle, should have thought of that, thanks martinhutch & howsyourdad.
Will try tomorrow.
Posted : 05/08/2019 10:32 pm
