Hi,
Has anybody had any experience trying to disassemble a DT Swiss 240 centrelock 15mm straight pull hub? I need to change the bearings in my front hub but for life of me cannot work out how to take the hub apart. The external axle spacers are proving the first problem, any help with getting them out?
many thanks
Just pull, or tap them out from the back.
15mm bar or your axle will twist/lever the end caps out on non straightpull 15mm cl hubs. Just the friction of the dust caps hold em in.
This. I'm amazed at the amount of times my hubs have fallen apart when I'm moving wheels around due to the lack of gubbins holding them together.
im pretty sure they just drift out from the non-centrelock side... going by the photos..
Yeah I scratched me head for ages with this. The washers as you call it (and so did I until after months of searching to buy a new one discovered that DT call em dust caps!!!!)... do just twist out. They need a good tight fitting maxle or 15mm bit of bar.
There is a spacer tube in the middle which makes it look impossible to drift out the end caps or bearings.
The spacer tube does actually have a rubber o-ring around it so will push back . still hard to get something on it but possible once you know your not doing any damage.
Good luck.
Hi just wondering how you got on with getting the bearings changed out any success ? I've had similar issues but managed to get the caps off by just pulling them downwards 90 degrees from the hub (No damage). I'm having problems getting the bearings out they wont budge which ever way I try and push/pull on them, just wondering if you managed to get them changed out and if you have any tips ?
Are you actually drifting them out? Generally if you drift the axle out that'll bring one bearing, then you can tap the other one out.
just download the technical manual for the 240 here
https://www.dtswiss.com/Support/Service-Videos-Documents?cat=Hubs
the pdf shows a detailed manual how to disassemble the hub and change bearings..
I've been following the manual instructions but still won't budge just wondered if I've missed something with these hubs as the force required to remove any other bearings from any other wheels I've had was far less I'll try again when I get home from work in a few weeks and see how I go.
Not sure if they've updated the 240 manual yet but it did omit the 15mm versions.
Found better joy with the 350 documents for an idea on how it all goes together.
No axle to drift out the bearings by the way!
Yeah I was using a machined pin for the drift but not joy.
I found getting the endcaps out the hardest bit.
That spacer sleeve in the middle will deflect a bit. You can get a screwdriver in one end, then push through to the inside edge of the bearing on the opposite side. You have to sort of lever it a bit to push back the sleeve to reveal the inside inner races edge of the bearing. Then slowly tap it out, no worries about damaging the bearing as your gonna bin it just go slowly and work round to try and keep the bearing reasonably square. A bit heath but worked ok.
Cheers for the tips I Gee.
Once you can get to the bearings they should just tap out by working around the edges with a drift. Might just need to hit it harder?
With any luck he's not still trying to get them out 3 weeks later...
