DT 240 hubs > DJ...
[Closed] DT 240 hubs > DJ frame
I just got a DJ frame that takes nutted hubs.. 10mm axle size.
All my wheels are through axle style.
Is there an elegant/reliable solution to turn my rear say 12mm thru into a 10mm bolt on?
Google is failing me. (rather than threaded rod and farmers nuts)
I have a 10mm RWS thru axle, but I'm not sure it will be resilient enough in horizontal dropout duties.
Looks like this:
Voltage drropout
Posted : 07/05/2019 6:21 am
I had a 3 speed dt swiss rear hub on a dirt bike once, with 10mm bolt. I would contact DT or a distributor or something
Posted : 07/05/2019 7:38 am
10mm thru axle with threaded ends so you can use nuts. Made from steel if your worried about longevity.
Posted : 07/05/2019 8:43 am
The DT240 singlespeed hubs can be adapted to use threaded bolts, not sure about the standard version.
Posted : 07/05/2019 10:30 am
I've made a 134*11.8 Ali rod with M10*1.5 threaded holes in the ends to convert a 12mm hub to 10mm bolt in. Never had any problems with it if you can find someone with a lathe.
Posted : 07/05/2019 10:54 am
